configure vrrp vlan vrid delete track-iproute
configure vrrp vlan vlan_name vrid vridval delete track-iproute ipaddress/masklength
Description
Deletes a tracking entry for the specified route.
Syntax Description
vlan_name
Specifies the name of a VRRP VLAN.
vridval
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command.
ipaddress
Specifies the IPv4 or IPv6 prefix of the route.
masklength
Specifies the length of the route's prefix.
Default
N/A.
Usage Guidelines
Deleting a tracking entry while VRRP is enabled causes the VRRP VRs state to be re-evaluated for failover.
The following command disables tracking of routes to the specified subnet for VLAN vlan-1:
configure vrrp vlan vlan-1 vrid 1 delete track-iproute 3.1.0.0/24
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
